1 - 11 of 11 Posts
99 Ford Taurus / hot car, won't start
My Taurus won't start when it's hot. It also dies occasionally when hot. I replaced the plugs and wires, and the problem persists. I went to Auto Zone and had it tested the guy seemed very novice, and he concluded it's the coil. I was wondering if that sounds right? The car runs like a champ until it get's hot.
When I say hot, I mean it's normal running temperature.
I wouldn't buy any more parts. The next step is to check spark when it won't start. You can buy a spark tester for under $20 and do it yourself. If you have good spark, check fuel pressure next.
By no start when hot, do you mean it turns over slow and/or weak?
Mmm, check your IAC valve (Upper left on the upper intake manifold). Sounds like it went out.
Bingo. Checking this and the MAF is a great way to start.
And a novice at Autozone? I can't believe that! (insert sarcastic eye-roll here) I never trust anything they say in my area. Very rare to find someone who knows what they're doing at Autozone.
1 - 11 of 11 Posts
