99 duratec taurus sitting at an idle the power steering whining saw a tsb for this is there any fix and does it mean the pump is defective ?
Whine
so any info if its whinning does it mean im gonna have to replace it or not .
First check is the easy check.
Suck the fluid out as much as you can, refill. Run it a few miutes, then shut off, remove the fluid and replace with new. This gets the air out of the resivor. May need to repeat after running it a few minutes, shut off, suck it out, refill with new fluid.
Sounds like air in the fluid.
thanks for the advice definatlety sounds like a logical reason as i just sucked it out and filled it not to long ago but didnt run it and do it again
