My 98 taurus all of a sudden when I tried to start it ran for about 3 minutes then died. Then will not restart after that. Took it to mechanics had diagnostic done and they cant find the problem. After $130.00 diagnostic plus taxes they want up to an additional $500.00 to do further diagnostics and then a flat rate if they cannot find problem. All new plugs were put in, we have spark, and fuel rail has proper pressure. I hear fuel pump when key is turned. Any ideas where i can start to look would be appreciated.I have spark to plugs ,It kicks like whants to start but does not,when it does start runs fine for 3 to 5 min and dies like someone turned the gas off and will not start right away but will no and then.Im at my end off me rope help please
Sounds like it could be a timing issue. Has that been checked?
Is the check engine light on?
Yes the engine light is on and we were given a p1513 code i think. Its for the intake manafold valve bank 1 is open. The engine light has been on for the last 3 years and never had an issue with it before.
3 years of a check engine light could be a lot more than just the secondaries.
