is it a problem if the yellow plastic around one of the relay terminals is melted a little bit ?? this relay is for the cooling fans
also is the vents blower controlled with the same relay ?? took that relay out now my vent blower ant working
My 97 has the same issue. the female socket is corrupt, and it eventually melts and
corrodes the spade contact on the relay. SO far, i have just kept changing the relay.
The only real long term solution is replace the female spade connector in the relay
box. I am not sure that is even possible. The other way is to cut the wires and
put in a new relay socket and external relay
but it still works right so i can put a new relay in that socket and the cooling fans will continue to work??
i don't want to have the cooling fans rewired to a switch
and i have no idea to why my vent blower is suddenly not working it worked this morning when i put the windows down unless it is tied in to that relay that was removed
