1 - 2 of 2 Posts
I know this is asked a lot, but I'm trying to install custom audio in my 98 sable. I've got everything I need, but I'm not used to installing audio in modern cars. So, before I mess something up I'd like to ask a couple of things. I'm installing my own amp, so, this would mean I do not even need the stock one, or the 18ft. wiring harness that scosche provided, correct? If I don't need it, wouldn't it just be a "standard" installation, with all the sub/speaker wires going to it then up the the head unit? Then the only scosche thing I need would be defrost,climate, right?
You need to run a remote turn on wire from the head unit to amplifier. You also need to ground the head unit, but there is a factory ground wire already. Are you going to amp all four speakers or just two? If you amplify just two speakers, you might still want to run the speaker wire from the head unit to the rear speakers.
1 - 2 of 2 Posts
