Runs fine cold and driving down road, but at red lights, it's stalling. New idle air valve last year. Manifold runner control replaced. Cleaned EGR valve and took TB off and cleaned the EGR port up. Temp gage read's normal. A p0442 is on, but had this problem before that.
Discussion Starter · #2 ·
Changed air filter and sprayed the Mass Air Sensor with the CRC spray made specificy for that sensor. Seems better, we'll see when it's hot out tommorow....
If it is not a Motorcraft IAC that is the problem. DO NOT use a Dorman and call it good. They are not built to spec and cause more problems then they are worth 9 times out of 10.
