My daughter's boy friend has a 97 with the Vulcan he bought when his 2000 FFV blew a head gasket. The car was good for the test drive, but went to the upper end of the normal range on the temp gauge when driving it home. We swapped out the thermostat, but now it is running @ the low end of normal with little to no heat. Some times he will hit a bump and the gauge will jump up to normal and will have good heat. He is not losing antifreeze nor is his oil level rising like he has a blown head gasket. The previous owner did replace the front head in the past year though.
The heater door appears to be moving. Read another thread about a bad water pump, I'm wondering if this could this car's issue ?? Any thoughts ?
