1 - 2 of 2 Posts
I was trying to replace the timing cover gasket on a friend's car this weekend but couldn't get the darn crank bolt loose with my impact so that I could then remove the balancer. I have seen a lot of misinformation as well as to whether or not the bolt on this engine is reverse threaded. Are there any crank holder/flywheel holding tools available for this engine like there is for the Duratec?
QUOTE (eurowerke @ Jun 2 2010, 06:19 PM) index.php?act=findpost&pid=808813
I was trying to replace the timing cover gasket on a friend's car this weekend but couldn't get the darn crank bolt loose with my impact so that I could then remove the balancer. I have seen a lot of misinformation as well as to whether or not the bolt on this engine is reverse threaded. Are there any crank holder/flywheel holding tools available for this engine like there is for the Duratec?[/b]
Put the car in gear and use a breaker bar.
1 - 2 of 2 Posts
