My '97 Sable GS wagon has the disc brakes in back, but while doing a 4 wheel brake job I discovered a potential problem. The Chilton's manual says the minimum rotor thickness is 0.500" but my rotors were 0.433" before machining and 0.417" after. The rotors had not been machined before. Does anyone have the correct specs from the Ford manual?
:glare:
:glare:
The minimum allowable thickness is usually cast into the backside of the rotor.
<div class='quotemain'>
:glare:
I did try that first, but nothing visible on either side. I'll try to clean deeper but still would like confirmation from the book.
Bad news. Went to the Ford dealer and checked a new rotor - 0.550". Min thickness is stamped as 12.8mm (0.504"). So the old rotors are way below spec. Mystery is they hadn't been machined so it looks like some cheap off-brand replacement. A lesson learned. :glare:
.500" is the min spec. They probably were above spec when new, but worn out that thin over time.
