Has anyone experienced this problem with a 1997 Taurus GL, with 3.0 Standard engine:
When taking off from a stopped position, when I accellerate midly everything is fine, but if I need to give it a little boost, the engine seems to hesistate 2-3 little lurches. Afterwards, it runs like nothing is wrong. Wires & plugs new, injectors recently purged. Could it be the MAF? If I disconnect the MAF, the engine does change a little, and back to normal after reconnecting. Do MAF's act up only at certain times/speeds? Any other ideas on IAC, or TPS maybe?
