(PLEASE HELP)96 taurus 3.0,Dash lights don't work,Turn signals don't work,Fourways work,When you put the key in the ignition and turn to on position the chime sound works.The battery is fully charged,I have power from the battery to the starter,but no power from the ignition switch to the starter,Thanks in advance for everyones help,Jim
My freind had the same thing happen on his 86 stang GT. As it turns out it was his ground cable. It was old and cruddy. Check your ground and power leads! Are your battery terminals clean, I mean really clean?
It sounds like a bad ground to me.
Good luck and I hope this helps.
Greg.
