My 96 GL idles funny. Upon starting, it will instantly idle at 1500 RPM and then slowly drop down to about 900-1000 RPM. After it idles around 900-1000 RPM for a moment, it will fall down to 500-600 RPM, stumble for a second, and return to 900-1000 RPM. It does this over and over. The car feels as if it is going to die but catches itself and returns to 900-1000 RPM. The car has never stalled out. Temperature does not make any difference. Any ideas on what it could be?
1 word: IAC (idle air control valve) :p
When its acting up, try tapping on it with the handle end of a screwdriver and see if idle normalizes. If so, remove and try cleaning with throttle body spray, as they are pricey, or replace.
IAC valve. I did try to clean mine (96 too) and it didn't help. I gambled with one from salvage yard and it worked (a few years now).
