I recently acquired a wagon wiper/washer switch (for the rear hatch). How do these buttons work? Do you have to push and hold for the function/feature to work? Do the wipers you just push the button to turn on and it stays wiping at a rate of X until either the car is turned off or the button is pressed again? How does the wiper sprayer work? May be reassigning some functions of my sedan to use the factory looking button setup.
Thanks!
Picture of wiring diagram (I do have partial harness):
Thanks!
there is two buttons one button (closest to the door) you push once it stays on wipes every min then there is the other one you push and hold and it will squirt washer fluid on the window and run the wiper blade i hope this helps
OK so it has no special settings the wiper is either on, swipe, then off for 59 seconds until it goes again. And you have to push & hold button for rear sprayer? Hmm. If you turn car off and turn car back on, will the rear wiper stay on if you left the control on next time you crank the car up?
Cool thanks for the info k8crd!
