One more time I come to this forum asking for some help.
I need to buy a bonded valve body gasket but there are various model numbers based on a 'stamp code' (when it exists) on the main control valve body.
Does someone know where this number would be? There is one number written on the side of the VB that ends with 14 in bigger size letters, but that should not be the stamp code since 14 corresponds to 96-97 and this car is a 95 (and I am 99% sure it did not have transmission work done).
Thank you for your help,
dC.
The circled area is where the code is located.
Thank you for your reply, in the mean time I discovered that the stamp code the manufacturers refer to is stamped on the bonded plate, not on the pump or main control VB.
Funny thing is mine has 8 94 stamped in a corner, but neither of these number is a valid choice, so I am going to go with the "no stamp" bonded plate.
