i am in need of your help. my 95 Ford Taurus stalled out on my wife coming home from work. I had it towed home and i have been working on it for two weeks now. the car is not getting any spark or fuel pressure. i have traced it down to what i found, iam not getting any volts to pin # 8 at the CCRM. i followed the wire to where it goes into the ECM, with a volt meter set on continuity and i get perfect continuity. i have been told its comes from the ignition switch, so i took the plastic cover off under the dash and brace above that and the small cross brace. i removed the wiring harness and looked at all the pins for corroded or broken terminals but they all look good. so i put them back together. wires in harness looked good also. check all fuses under the hood none where blown. i removed the two screws holding the fuse block to the back of firewall, removed bottom cover of fuse block and inspected all wires. they all look perfect. nothing broken or corroded. so i thought do a continuity test on all those fuses. they all tested perfect, so i put the block all back together. so i thought check the fuses under dash, samething they all test perfect continuity. none where blown. any help would be very appreciated. the car cranks and turns over but will not start.
