I have a 94 MTX with no spark.. All fuses are good. Tach works when cranking, so crank sensor should be fine. Cam sensor has power. Has good fuel delivery. And a new DIS Ignition module didnt do anything. Everything is good but still NO SPARK... Might be the Coil Pack after all. Any ideas? And if its not the coil pack, then what?
I would suggest testing the coil pack. I had a similar issue some time ago on my daughters car , I tested about everything including plug wire resistance and still could not find the problem. It turned out to be the plug wires. Strangely enough all of them failed at the same time. This is the only instance I had/have heard of this happening but it is worth finding a known good one to test spark with.
Turned out to be the Crank Sensor AND a bad ground to the Ignition Module..
Good call on the crank sensor jedhead.
Good find, fix & reps to you for the repair feedabck .
