Hi.. I'm new here to TCCoA.. I've been reading posts looking for a possible answer to my problem, I didn't find anything so I'm posting a new topic in hopes someone can help me with some tips..
I have a 92 Taurus LX with automatic column shift.
A friend told me that I could have the car if I could move it. The column shifter won't shift out of park.
the keylock collar spun in circles on its own, and the original key was very worn. I somehow got the shifter into neutral and started up the car, and drove it to my place. I replaced the ignition lock with a new one.
I removed the cylinder easily by putting the lock into the RUN position, pushed the little nub on the bottom of the column and the cylinder slid out with minimal effort. I put a new cylinder lock in and everything was good. However the existing problem is still there. I can't shift the selector out of park when the switch is in the RUN position.
I found that when the keylock position is in the RUN position, the selector will not move out of park, but if I crank the key back 1 notch, I can move the gear selector out of park. from there I can start the car in neutral. I can shift thru all gears even reverse. but if I shift into park, I can not shift out of park unless I turn engine off, crank key back 1 notch and shift back into neutral.
I imagine that something isn't aligned, the ignition lock is keyed so there's no way I could have put the cylinder in crooked. the switch that gets turned by the cylinder is also keys so I couldn't have, or rather I don't think I put it in wrong.
Either way the condition still exists...
How do I adjust whatever it is I need to adjust???
Do you notice that the brake lights do not come on when it won't come out of park? Replace the brake switch on the brake pedal arm.
This happens all the time with the E450's and I always chase every other problem possible until I'm frustrated (then I go and get a coffee) and then I check the brake switch and it is always the answer...what is the definition of insanity again????
Definitely the brake pedal interlock.
So what you're saying is if the stoplight switch isn't working, the gear selector won't come out of park??
I had no idea they were tied together..
I haven't noticed if the brake lights work or not, but I'll check ASAP.
Cool... any idea how to fix/adjust or remove it??
