'Is it possible I have a short sonewhere?
...Definitely
What are the odds that all 4 windows are off track at the same time?
...Doubtful
Use your multimeter and test for ≈ 12 VOLTS.
ohms doesn't tell u if wire can carry the 12v load.
Do door locks and interior lights work? If not, check wiring in black canister.
Black canister between driver's door & body; Unscrew to open [many turns of the bolt in top] - look for shorted wire - very common
Pull the drivers door panel, disconnect motor, jump ≈ 12v to it, reverse polarity to change direction.
Driver's door window controller - use schematic to test
...Definitely
...Doubtful
