We recently had the pleasant experience upgrading two 6th Gen Taurus' to a full HID Setup. We decided to keep it OEM+ on the first one and for the second one we did an SHO Paint scheme but instead of regular black we had the housings color matched to Ford Tuxedo Black Metallic
OEM Halogen Projector with Dimpled Lens
Morimoto D2S V5 with E46 BoschA/L Conversion Brackets ( Notice the Clear Lens with the Blue AR Coating)
OEM+ Conversion
SHO Style Paintwork Colormatched to Tuxedo Black Metallic
Output Testing on 45W Hylux Ballasts with Morimoto 6500K D2H Bulbs
These were cut open since Ford Permaseal has a reputation for being extremely difficult to work with and 90% of the time the channels get damaged beyond repair. If you do manage to seperate them by baking then you have the tidious task of CLEANING all that sealant out. Since time is money, we use an ultrasonic knife to cut the lenses from the housings then plastic wield it shut after the conversion. This reduces the amount of time needed to build the lights and the end result is much cleaner and professional look.
I'm considering a set of 17" wheels for my 2013 Limited for winter tires.
1. Will stock 17"s fit?
2. What will need to be done with the TPMS stuff?
I'll most likely source these from a Flex or Taurus in a nearby junkyard.
Thanks.
Last night I was sitting in my car messing with the settings. I tried to change the ambient lighting settings, and when I tried to move the slider down to dim it just went back to the top and if I tried to click on a different color, it wouldn't do anything. I've never had this issue before...
TPMS stands for Tire Pressure Monitoring System. As part of the TREAD act passed in 2000, all MY 2008 and later vehicles must include a TPMS, although some Ford SUV's had a TPMS as early as 2003. The TPMS is basically a system of wireless pressure sensors inside each wheel that monitor the...
