I have an '03 with a 'tec engine. It has ~115000 miles on it. It has been missing for awhile so when I took it in for the yearly inspection, I asked them to look at the misfire problem. I have received the engine trouble light twice in the past 2 or so months but the light cleared on it's own. It misses at idle and does a pretty good buck if I'm cruising around 30 to 40 MPH and slowly push down on the accelerator. I can pretty much make it buck at will. Does not appear to miss at cruising speeds, at least it's not noticeable. Fuel filter changed at 80,000 miles.
It was put on the computer at the shop.
No codes were present.
diagnostics said the problem was a #6 misfire, seen on the computer.
Plug was replaced - no change
wire was replaced - no change
coil replaced - no change
injector replaced - no change
Compression was checked and showed OK though I don't have the number.
The mechanic said the injector was getting a signal to pulse and it looked good.
They are at a loss and of course I am. A bit of help would be appreciated. Their suggestion was to take it to ford.
