Case bolts, all figures are lb-ft unless otherwise specified:
Case to chain cover (10mm socket size) - 19
Case to chain cover (8mm socket size) - 9
Chain cover to case (10mm socket size) - 18
Chain cover to case (24mm socket size) - 23
Chain cover to case (13mm socket size) - 32
Chain cover to case (8mm socket size) - 8
Chain cover to case Torx bolts - 9
Case to stator support - 8
Transmission range sensor to case - 89 lb-in
Fluid pan to case (lower reservoir) - 9
Overdrive sensor cover to case - 8 lb-in
RH engine mount-to-transaxle case bolts and nut - 46
Dust cover to case - 89 lb-in
Shaft cable stud chain cover to case - 23
RH front anti-roll restrictor bracket-to-transaxle case bolts - 46
Exhaust hanger-to-case stud - 10Nm
