1 - 2 of 2 Posts
Today I had my 3rd cat replaced with a piece of straight pipe. I figured that now would be a good time to get some solid 0-60 times. Here are my findings.
Mods: - K&N cone in engine bay (Yes, I know, a true CAI is in the works)
- Borla mufflers, no resonator
0-60 times: All runs done within two hours of eachother. Outside temp reading pegged at 74F. 70% humidity. The straight is an 1/8 mile perfectly flat stretch.
- 3rd cat in place: First run - 6.71
Second run - 6.74
- 3rd cat replaced with straight pipe: First run - 6.54
Second run - 6.61
- Running right off the y-pipe: First run - 6.84
Second run - 6.89
- With stock exhaust (before ANY exhaust work) I ran a consistent 6.85
So as you can see, no low end torque was lost with the removal of the 3rd cat, in fact it made me quicker. Running right off the y-pipe, however is not the way to go. But I will tell you this. It sounds SUPER sweet. Almost deafening. Sounds like an F-body on crack. I agree that every V8 SHO owner should listen to their exhaust uncorked at least once before they (or their SHO) dies. You will not regret it...though your neighbors will.
even mine is a 3.8 L no cat no resonator and a straight pipe lollllllllll nice sound the only thing that pissing me off is the rev limiter :angry:
1 - 2 of 2 Posts
