for my 2007 Taurus sedan , I need wiring diagram for the high mount brake light circuit to repair an intermitting high mount brake light operation . Thanks you very much.......carl52
Likely poor solder joint(s) in the LED bar itself.
The third brake light on the wifes 06 Vulcan failed a few years ago. Had power at the LED bar verified with a test light. Picked up a red LED light bar from Ebay for around $5 that was virtually the same length as the original. Removed the dead LED bar from the original housing and used JB Weld to glue the new LED light bar into the original housing. New LED light bar is somewhat brighter than the original.
2001 Taurus SES Sedan in Chestnut
First question is which high mount brake light do you have, is it in the rear window or do you have a factory installed rear deck spoiler?
