Hello, I am looking to replace my 3.5l non turbo in my 2010 Taurus SEL AWD. No thanks to what sounds like the water pump giving up on me after doing some reading.
Mine is a VIN code W. I am having issues finding a motor anywhere under the vin W. Are all the single cam 3.5l motors the same in all the cars around those years?
There seems to be a build split as well, does anyone know what the reason behind the split is?
And are the 3.7l from the Explorers and Lincolns compatible?
Compatible as far as direct drop in or would I have to reprogram my ecu or change out the ecu entirely?
All motor mounts match and the trans?
Just trying to expand my search here if I can as I see plenty of listings for other vin codes. Any advice would be helpful.
Also are there any DIY for engine replacements? Especially for out of the top, I don't have access to a lift to do this.
