Well at 107k mi it looks like I DO have a timing cover leak in addition to my weeping rocker cover gasket. For a whopping $12.69, I verified this with some UV coolant dye from O'Reilly's and a cheap ebay UV flashlight. It weeps just a teeny tiny bit when starting up from cold and then stops. I just ordered an OEM cover, gasket, seal and water pump from Tasca. It's too much work to be cheap and save $110 with the Dorman part. I've had this baby since new in 11/99 and she's going to college with my kids in 5 years. Then *I* get a new ride and my wife gets the 02 Ody :lol2:.
It's way too cold to work in my detached garage so I'll tackle this once the weather gets warmer and I'll have parts in case it lets go and I have to take it to the shop
Just a few quick questions:
1) According to the factory manual I can pull the cover out with the pump attached (pulley removed of course) without having to pull the P/S pump or bracket...correct?
2) You don't show the pulley installer. Will this one work?
Pulley Remover and Installer Set
TIA
