1 - 14 of 14 Posts
the story:
2k taurus FFV
clogged heater core every winter; reverse flush and have great heat all winter
heater pipes rot out; replace
heater core clogged nearly solid; replaced
gauge running above half way; installed 160* stat and gauge is all over the place
i think the radiator is mostly clogged up
what you think?
You're going to have to replace the entire cooling system and flush the block out. It's a common Vulcan problem. The 160 deg thermostat is only going to compound your problems.
so,
i replaced the heater pipes, heater core, water pump, rubber hoses and soon the radiator
this should be it?
i also had the heads cut last year when the gaskets disappeared; all the coolant ports looked brown but clear....
Make sure to use store bought 50/50 premixed coolant for refill. Diluting your own with tap water can cause rust problems all over again down the road.
right.
i've also been using an additive i got from the dealer that allegedly prevents this from happening as bad
Discussion Starter · #8 ·
it pings less now and the gauge runs closer to where it was when i bought the car
i think it might be time to flush it out with some muriatic acid
if youre gonna flush the system you need to pull the freeze out plugs to get the hose water completely out. use the premix its easier. why would you want to use rain water and what for?? look at it this way. spending a couple dollars more to resolve the problem ( premixed ) will save your cooling system and engine.
Discussion Starter · #13 ·
Rainwater can be good so long as it doesn't have leaves or bugs in it.
sweet
i should use the water from my dehumidifier first
next time i spend some quality time with the car, i will be pulling the block drain or drains depending on if the transaxle is in the way
If you want to mix it yourself, use distilled water.
Tap water has calcium in it ("hard water" - more or less, depending of area). Even the rain water can be acidic (also dependig of the area).
Personally, I pay extra and use the 50/50 mix...
1 - 14 of 14 Posts
