2016 SHO 3.5 ecoboost Getting a p0138 which turns up bad o2 sensor in google: bank 1, sensor 2. Haven't been able to verify. Wondering if anyone has gotten this and how to determine which sensor this corresponds too.
This is a similar mockup to the SHO - less the turbos - but the same idea.
Thanks for that diagram! you wouldnt happen to know part numbers, or where i can find part numbers for each sensor would you? Im surprised a google search for bank 1 sensor 2 for ford taurus SHO would not yield any helpful results. I called a local autozone and they didn't seem to know anything.
Looks like an NTK or Denso OEM - Downstream Sensor part # NTK 22139 or Denso 2344491
Be sure to confirm the wires match before purchasing - I can't tell you how many times I have bought almost correct parts.
You can also go to Rockauto and look up the part for your car (and use our discount code in case you decide to buy).
Edit: and in the terminology of the catalogue you need a "downstream right" sensor. The "right" side of the engine is cylinders 1-3.
