Hello all,
I have seen threads that show methods for accessing onboard diagnostics for the issue I am experiencing with Defrost only, regardless of the choice on the screen. But the methods shown require a key and buttons for the HVAC system that I do not have on my SEL electronic screen selections.
Discussion Starter #2
I have made some progress in the self-diagnostics for a 2015 sel with keyless entry.
The Hvac system has buttons near the shifter, Push the front defrost and fan power buttons at the same time and release, after a second push the fan power button again. The fan speed will drop and you can hear the modules associated with the Hvac in the dash activate.. Out of the three that are visible to me, the one on the driver side is not producing any noise when the two on the passenger side cycle. I need to identify the module visible from the driver side floor.
Ok, i guess no one knows enough to offer assistance.on the keyless entry cars with the HVAC that does not run on a vacuum.
Thank you for all your help and insight.
