I have a 2013 interceptor. When I turn the key to the start position I get the chime and everything comes on like it should but the engine will not turn over. No click or anything. The battery is fully charged and all fuses and relays are good. The last couple of times I started the car when I turned the key to start there was a pause before the engine would turn over. Does this sound like a starter issue? Anytime I ever had a starter go out it just stopped working. No hesitation on previous starts like this one has.
Remove the ground wires, clean wire and mounting surface to bare metal, reconnect - confirm batt terminals clean and tight. Most auto parts stores can test the starter for you (you can also test it off the car). See YT videos for solenoid/starter tests.
