1 - 1 of 1 Posts
I'm losing coolant very slowly. It's not the pump. The sheath on my hose from the overflow is getting saturated with coolant. I replaced the hose thinking that was the culprit, but the leak continues and is still collecting at the lowest point of the hose. The only parts above the leak are the reservoir and the hose clamp. I have never seen a spring clamp lose tension, so I'm wondering if anyone has ever had to replace their reservoir? Are there any other points that would allow a leak path near the bottom of the reservoir that I'm not seeing?
Thanks in advance.
1 - 1 of 1 Posts
