1 - 13 of 13 Posts
Good day Taurus Club enthusiasts,
My 2011 Ford Taurus Limited AWD recently took me to the garage for some highway-speed vibration caused by a slipped belt on one of my tires. I ended up replacing the rear tires and while the mechanics were under there they found a shock absorber in need of replacing. It was leaking pretty substantially, which I witnessed myself, on the same side as the tire.
Now I am searching the internet everywhere for any information I can find about the 2011 Taurus rear suspension such as diagrams of how it's all put together, videos of people DIY-ing the rear shocks, etc. I have come up pretty empty handed except for what I have gleaned from a few posts here on Taurus Club.
I've watched a Youtuber "ChrisFix" replace the rear shocks on an old Windstar with ease, but I fear this is not the case with my Taurus. It looks a little more complex when I stick my head under there and I'm debating whether I pay a mechanic the $200 labor to install the new Monroe shocks I just picked up yesterday.
Is anyone here able to offer me some advice? I'm a tinkerer, not a mechanic. But I refuse to believe this is as difficult of a repair as it's been made to seem by Firestone.
That appears to be exactly what I need. Hopefully I can bang this out in an hour or two tomorrow. I will update. Thank you for your help.
It's surprisingly extremely easy to replace suspension parts. As long as you have a way to lift it, it's like legos. Take out one part after another and then reverse the process with all the new stuff.
Here's a couple links. The first one is an install (Not necessarily a tutorial) of coilovers on my car and the setup should be identical to your 5th gen. Second one will be a snapshot of my service manual with instructions and a picture of how to remove the rear shock absorber.
http://www.taurusclub.com/forum/121-5th-6th-gen-suspension-handling-brakes/341146-so-i-ve-discovered-megan-coilovers-not-sho-exclusive.html
https://i.lensdump.com/i/87l4dH.png
https://lensdump.com/i/87lKM1
The diagram image is kinda crap but it's something. Instructions are the second picture.
Excellent information. I feel much more confident. I did not have a chance to do this project, but as soon as I can I will report back the results.
Thank you both for your help.
  • Like
Reactions: AdmiralSparklez
Just a heads up, you may need an alignment after replacing your rear shocks. Usually an alignment is needed after doing anything suspension-wise.
I managed to get the stabilizer bolt nut off and access the lower bolt on the shock absorber. Removing that was no problem. Then I went to the upper bolt and realized I probably didn’t have the right tools.
I used a tiny socket to rotate the shock tower rod while my buddy held the nut in place. I couldn’t figure out any other way to do it, unless I had an 18mm wrench which I don’t. With the wrench and tiny socket I most likely could put this back together but had to call it a night.
It wasn’t terribly difficult. I’m just wondering how you properly torque the nut holding the shock tower rod? Am I supposed to have an 18mm torque wrench? I can’t use a torque wrench with interchangeable attachments because there’s no way to hold the shock tower rod in place so it doesn’t rotate. The dust shield on the shocks are a plastic sleeve that cannot be moved aside like some I’ve seen.
The parts provided by Monroe with the shock also don’t give me the highest confidence. Ford has this nice rubber grommet that actually provides protection from the shock tower rod hitting against the metal frame because it seats right inside the opening for the rod. The Monroe replacement is just a rubber donut that rests against the metal frame but leaves the rod to press against the frame.
I can post some pictures showing the difference. I’m inclined to use the old rubber grommet because it’s in good condition still.
I want to thank those that helped me figure out what I was doing. I’m what Harbor Freight Tools refers to as an “avid do-it-yourselfer”, but I haven’t had a ton of experience and everything I got from you guys helped.
One of my pics is the new rubber grommets next to the old ones. You can see an obvious difference but they still fit just right. My other picture shows the 2 old shocks and 1 of the new ones. Any guesses which of the old ones was bad?
I found that I needed to get some tools that I didn’t already have when starting the job. A 1/2 drive torque wrench and 18mm socket were used to torque down the thick bolt on the bottom of the shock. I had to use the new replacement nut from the kit, the original nut was welded onto the old shock. Not a bad idea to keep it in place. The new nut was 21mm and I used an offset wrench to hold it in place while torqueing the bolt. That worked out nicely.
One thing I ran into was that the shock tower kept rotating when I was trying to unscrew it. Eventually I used an 18mm offset wrench to hold the nut, and a 15/32 socket on a 3/8 drive ratchet to unscrew the shock tower (which I actually did by clockwise ratcheting it against the nut). Definitely some uncomfortable angling doing this. To put it all back together I did the shock tower last, kept the control arm supported with a jack. That seemed to work. I hand tightened the new nut and then used a 19mm offset wrench to tighten it. The new nut was 19mm whereas the factory nut was 18mm. Interesting. I didn’t manage to torque this nut.
The stabilizer arm required a 15mm closed wrench to undo and re-install. I used a small plier to hold the nut on the back side otherwise it spins endlessly. The nut on the back side was not a 15mm, might’ve been a 16 or 17 but I’m working with a bunch of random tools that I collected throughout the years.
Thanks again everyone for your help. I’m onto pads and rotors next.
  • Like
Reactions: RLW001xxx
Thanks for posting. I am about to replace my Struts and Shocks...probably go with Ford Motorcraft or KYB.
Front: MOTORCRAFT AST886 (L) MOTORCRAFT AST472 (R) or KYB 335611 (L) KYB 335610
Rear: MOTORCRAFT ASH1255 or KYB 349165
I don't know about anyone else, but working on cars is really satisfying (sometimes aggravating). Working in an office does not offer the same sense of accomplishment.
Discussion Starter #10
RLW001xxx,
Glad to see this thread helped more than just me. A few lessons I learned after doing this.
First off, I ended up buying Monroe OESpectrum shocks from O'Reilly Auto Parts. I got the pair for about $152 online after a $25 coupon. NOT BAD!
I was able to torque the lower bolt and nut on the strut, but could not torque the upper bolt/nut because the new strut had a square head on the rod, not one that could be held with a socket like the old one. I used an offset wrench and ratchet to remove the old one as I indicated. I just went with what seemed tight.
Good luck! I loved doing this. It was a lot of sweat, a little blood, and pure joy. Took me a while to get my bearings but now I feel accomplished. I work in a hospital so the mechanic work is a nice change. Different smells...
Finally, got around to replacing my rear shocks...
Took me about 90 minutes start to finish.
Tools:
Needle-nose pliers to remove "plugs" that hold trim around upper shock mount.
8mm deep socket and ratchet to prevent shock shaft from turning.
15mm wrench to remove end-link nut.
18mm wrench to remove top shock nut.
18mm socket to remove lower shock bolts.
19mm socket to remove lug nuts.
Floor jack.
Car ramps.
WD-40.
What I did...
Sprayed WD-40 on end-links and lower shock bolt.
Put down rear seats.
Removed "plugs" to allow access to top shock nut.
While holding shock shaft with 8mm socket and ratchet use 18mm wrench to remove top shock nut. This is a PITA.
I left the top shock nut finger tight.
I decided to loosen top shock nut on both sides.
Loosen lug nuts with 19mm socket.
Raise car with floor jack.
Remove wheel.
Place car ramp under control arm.
Lower slightly to take tension off sway bar.
Remove 1 end-link nut with 15mm wrench while holding shaft with 8mm socket.
Remove lower shock bolt with 18mm socket.
Raise car slightly.
Remove top shock nut and remove shock. The rubber insulator may stuck in body, remove if your new shock includes one.
Install shock and finger tighten top shaft bolt.
Install lower shock bolt and tighten with 18mm socket. I put some Blue Lock-Tite on bolt before installing.
Attach end-link and use 15mm wrench while holding shaft with 8mm socket.
While holding shock shaft with 8mm socket and ratchet use 18mm wrench to tighten top shock nut. This is still a PITA.
Install wheel and tighten lug nuts with 19mm socket. Torque lug nuts to spec.
Now do the other side.
Install trim and "plugs".
Put up seats.
Drive around the block to test your work.
Put away tools.
Pat self on the back and have a beer...I just saved $200 bucks.
Tools:
Floor jack.
Car ramps.
WD-40.
What I did...
Remove wheel.
Raise car slightly.
Put up seats.
Put away tools.
I did the same work on mine. Like someone said a post or 2 previous to this one, I wasn't to confident in the method of top mounting that the Monroes came with. I was able to peel the factory ones off of the washers and used them with the new shocks. Nice ride and quiet.
And only 1 beer?
Thanks for the posts on this, guys. It helped me out. I did my rear shocks last weekend, and then front Monroe Quick-Struts yesterday. These forums always help, so thank you. Some of my learnings after doing this: after the rear Monroe OE Spectrums, there was noise on bumps. I kept thinking the issue was the top nuts needing tightened down (I used the Monroe bushings and nuts), but it was actually the bottom bolts/nuts. I thought I had them "tight", but they had to be especially torqued hard to stop the noise/slop. As for the fronts, no issues there. The hardest part was getting the two bolts out that attach the strut to the knuckle. You'll need a pinch punch to put on the bolts before hammering them out so they don't "mushroom". Other than hitting really hard to get these bolts out of the knuckle, there wasn't any issues. I had clearance to get the struts removed. I was worried about that because there was a 2010 Taurus video floating around saying you had to do something with the CV/axle, but I didn't have to. I did protect the CVs with a doubled over piece of thick cardboard, so the struts wouldn't come down and tear the CV boots. I was worried about getting the quick-struts lined up in there to start threading nuts onto the top mount bolts, but was able to get it done (alone). Got an alignment right after, and it rides way better! The OEM rear shocks were actually shot, especially one where I'd compress it, and it took several minutes to even extend back to length! (I have 95k on a 2013). I still have some deep, "thudding" noise on bumps, and suspect it to be the lower control arm/ball joint assemblies. That doesn't appear to be too insane of a job (hopefully). My rubber bushings on the control arms look to be corroded out, it's crazy. Now, for that job... RockAuto looks to have the lower control arms for a good price. If any of you have done those, and have any learnings/advice, I'd appreciate it.
1 - 13 of 13 Posts
