1 - 20 of 21 Posts
Living in Indiana has been hard this winter, but with a heated garage and low miles and usually a clean not driven each day great Taurus, the chrome is peeling around the tail lamps! Just noticed this today and could be salt related or the low temperatures and snow? Any one else, now after checking, notice this or just lucky me?
Thanks!
Hi Rick,
Just joined earlier today, while looking up info on the same problem. I just noticed the chrome peeling this past Wed., and I know I'm pretty sure it wasn't there the previous week when I was out shopping and then hosing down the salt on the car.I live in Syracuse, and wondered of it had to do with the bitter cold and snow we had last week too. I took it in to the dealer on Thurs., they took pictures of all 4 sections of the lights and submitted it to Ford. In five minutes, they responded back with approval for replacement of all 4 sections.They'll be in towards the end of the week.Still really not sure what caused it, one of the service people mentioned a Fusion had come in last week too, and he thought it was some sealing(coating) problem.I just bought my car used with 13.600 mi on it on 12/23, other then for this, I really love the car. I drove to NY for the holidays and really enjoyed the ride, handling and gas milage, not to mention the "that's the new Taurus" comments.I now have just about 14950 mi and all is well .Hope this helped you out.
Got all four tail lamps replaced under warranty after Dealership took a ton of pictures. Yes as others have noted pictures not only of the defective lamps, but the spedo and VIN number were required of Ford, for approval.
What do you think all four lamps list for? Would you believe $756.24!
Hope these replacements are not from the same, now defunct vendor.
Chrome Peeling Tail Lights 2010 SHO
Just came from dealer. Larry Hill Ford Cleveland TN. They played dumb. Service writer Robert is a real know it all. Tried to tell me it was because my bumper was repainted? Anyway, Called Ford, have a case number. Will follow up to let you know what happens.
Follow -up
Hi Rick,
Just a follow up to my earlier post.My lights were replaced as stated above looked perfect!! Unfortunately in April, I was hit by someone who ran a 4 way stop sign and my Taurus was totaled due to a small crack in frame where the impact was on the front driver's side. I was able to open the door & walk out, just a bit shaken.Due to the fact that I was able to walk out of the car on my own,and that I loved the car, I was able to find the exact car after a month of searching. Got my new one on May 9th, and noticed the same thing again (last month) with the light trim again, only this time I noticed bubbling up on my grille too. Took it to the dealer, they again took a bunch of pictures and Ford replaced all the lights and grille 3 wks ago. Everything looks great now, except that I just noticed the chrome on 2 of my wheels is chipping off now. I do not parallel park,as all the parking done is in lots & my driveway(my street actually has no curbs & sidewalks),so it can't be because I hit anything, plus there would be a dent, which there isn't. The 2 wheels affected are also on opposite sides too, front passenger and rear driver sides. Curious as to see if anyone else has run across this problem??
Since the problem is well documented by now, there usually isn't any problem getting the peeling chrome taillights replaced, my dealer did it with no problems, just needed photos and vehicle ID info for Ford. I am thinking that the chrome wheels would be covered as long as the car is still within the warranty period.
I believe that since this is a well known issue both the tail lights and the Ford badges, that both should be taken care under the TSB. @Tony, even though your warranty period is up, this problem has occurred on almost all of the SHO's produced for 2010, so if you have any kind of relationship with the dealer, they should help you get this taken care of...however, they do have to take pictures of the tail lights and submit it to Ford for approval...this is standard procedure, so if the dealer tells you that, it is the truth.
1 - 20 of 21 Posts
