1 - 15 of 15 Posts
The 2007 Ford Taurus 3.0 Vulcan, pretty much all options think it has all options, but the passenger side axle keeps popping out, also has a parasitic draw that I can't figure out it's got a brand new alternator, idler and tensioner, but the major problem is the popping out of the axle, about a new axle but I want to make sure it's the right one before I go installing it I have to drive the car and here in a little bit I'm probably going to get stranded again so I was looking for any advice I can get. Also does the in too be a clip in shaft ??? Ty for your time
Car Vehicle Wheel Automotive parking light Hood
Tire Car Wheel Vehicle Plant
Font Auto part Rectangle Circle
Discussion Starter · #2 ·
My Axel pass side, keeps popping out while I drive the vehicle, trying to figure out whether it needs to be replaced or not I think it might be too short the axle boot is always compressed on one side of car, bought another axle but I want to make sure it's the right one that and I wonder if there's a clip that's supposed to hold in trans any help plz I keep getting stranded in this car and I can't afford another tow I have everything with me to fix it
Communication Device Font Screenshot Gadget Technology
Font Screenshot Communication Device Gadget Parallel
Font Screenshot Electronic device Communication Device Multimedia
Font Material property Rectangle Screenshot Communication Device
2007 Taurus only came with the Vulcan engine. The axle has a round clip at the end of the splined part of the axle. This clip pops into place once the axle is inserted properly into the transmission differential gears. It takes prying oiut with a pry bar to pop it loose. Eother it was not inserted enough into the transmission or the clip is not there and or the transmission part is damaged. Most likely it was not inserted enough for it to pop into place.
Cylinder Household hardware Gas Art Nickel
I always use a parts site like RockAuto to see what parts fit my cars. It looks like there are two different axle lengths for the car.
2000 Taurus SES 12v
So I'd say it is the wrong axle. Left and right axles are not the same, the right one is longer. Look carefully at Automender's link to the Rockauto catalogue.
I don't know whether it is at all possible to accidentally install a left axle on the passenger side though.
One side had male end other side has a female end. Left is female as I remember it.
Can't mix them.
2017 Ford Taurus
Common sense approach to battery draw
I'd say it is the wrong axle. Left and right axles are not the same (the right one is longer). Look carefully at the Rockauto catalogue.
Can't install wrong side. One side is male, other is female. Pictures on RA.
2001 Taurus SES Sedan in Chestnut
The original OEM CV axle numbers were TX 440 & TX 441, they are now obsolete, so you have to cross reference to the latest numbers for the proper fit and the driver side is the same on both tranny's, the passenger side is shorter on the AX4N 19 BOLT than the AX4S 17 BOLT tranny, and by the way the AX4N was built for the V8 motors(SHO and Lincoln Continental) so it is the stronger and better tranny. Good Luck
Discussion Starter · #13 ·
[/QUO
Then why does it keep popping out when driving something isn't right, maybe no clip.
you dont hear anything flopping around under the hood do you when starting and stopping?
its a long shot, but make sure your motor mounts are intact.
  • Like
Reactions: kekaye56
1 - 15 of 15 Posts
