Hey all, the Frankenstein Taurus broke again. As discussed before, it's a 2006 with the 3.0 Valcun engine. It's called the Frankenstien Taurus because when I bought it, the guy said it was never in a wreck but as we found out, it had blown heads and fenders from a 2004 (has the 24v stickers on it despite being a 12v), and had paint overspray on headlight wires. 2 years ago, I replaced the heads and most associated parts to the top of the motor since I bought it and was troubleshooting a cyl 6 misfire. Right now, I'm fighting with a high idle again. I start it and it immediately jumps to 2200 - 2500 RPM. The original IAC I had in it was installed 2 years ago and is Motorcraft. Back when I was first starting to troubleshoot the misfires years ago, I bought a cheap aftermarket one and then I learned on here to only buy Motorcraft... which I have ever since. Everything is Motorcraft on this car. Back to the now. I noticed it was starting to have issues where it didn't want to slow down while in gear and when I put it into neutral, it would spike to 2k-3k RPM every time. It was only intermittant though so I figured I had time to troubleshoot it. I pulled the original IAC and threw in the aftermarket one. Problem seemed resolved for a week and then that one started acting the same way. I removed it, replaced the IAC gasket and put the original one back in and that's when it went from an intermittent issue to a full time high idle issue. I ordered a new IAC and a new gasket, installed them last night and it still revs 2k-3k as soon as you start it. Tried playing with the throttle but didn't seem to make a difference. I'm not popping any codes or a CEL. I've sprayed down the top of the motor with carb cleaner and it doesn't seem to change RPMs so I don't think it's a vacuum leak. Any other thoughts or recommendations? I could be wrong about the vacuum issue but that's why I'm back on the forums. Thanks for the help!
