Hello to everyone on the forum! This is a great site! I also belong to FTE (Ford Truck Enthusiasts)
I am mechanically inclined. I own 3 OBS F150's. I have owned 5 OBS F150'S total and I also owned a '97 Ford Taurus from 2000 to 2002.
I have a few questions I need guidance with if possible.
I recently inherited my mothers' 2005 Ford Taurus SE, 3.0. It has and did have numerous issues that I have been slowly working on. Its had 85k miles original, she is the second owner since 2006. The car lived its life in the south and now resides on Mid-Missouri.
The most recent issue is cold start, rough idle. In Louisiana, we rarely see cold mornings below 25°F. Here in Missouri, that is usually the average high in winter. Overnight cold soak, creates a rough, hard start and stumble, but clears up. Sometimes, even when its colder, it's a 2 key startup as the engine will die. My wife just found out about the 2 key startup. She started it, came in, waited 10 minutes, realized the defrost was blowing cold air since the windshield had not cleared of frost. Had to restart it again.
I removed and cleaned the IAC valve and it really wasn't that dirty. Haven't touched the MAF sensor yet.
After the 2 start try, I finally received the CEL, pulled codes and had P0300 and P0316.
My mother had it diagnosed 2 years ago as it will misfire even in hot weather. I ordered her a new Motorcraft coil, and the issue went away. I haven't noticed any misfire while driving or when its idling after started regardless of temp outside.
What I don't know about are plugs and wires. They look to be original OEM. She nor my late father mentions anything about that being replaced since they owned it.
I visually check the appearance of the CKP and the pigtail and it looks fine, but have not removed it and inspected it.
I replaced the fuel filter with a WiX unit. Really nasty crud in the filter when I let it drain into a clean container, but otherwise that seems to be ok. I've seen far worse, so I feel that and the fuel pump are fine. I've driven it really hard running fuel injector cleaner through it and running premium fuel as well.
I do know it's a FFV Taurus but can't remember if the engine is a Vulcan or Duratec.
I've replaced busted gas cap, had an emission code and found it broken.
Dropped transmission pan, replaced filter, flushed and refilled with Certified Mercon V.
Just had my 2nd child, a healthy baby girl. I have a 2.5 year old son. So, I had to bite the bullet and have a shop replace lower passenger side ball joint, passenger side tie rod, and the HP power steering line O-ring. I have all the tools, but no time for a DD family car.
If anyone has thoughts, ideas about those 2 codes and how to clear the startup, rough idle, I'd love to hear them.
Thank again!
Thank again!
