Hello,
I have 2004 Ford Taurus with high idle issue. I did a live data scan with my OBD2 tool and the RPMs during cold start is approx. 1450 and when driving or at operating temp, it stays around 925. Also, when the AC/heat is on, the RPM drops to around 750 to 800.
There are no check engine light/codes. I sprayed brake cleaner around all the hoses/vacuum lines and it didn't make any difference. I swapped the throttle body & MAF sensors and it didn't resolve the issue. Also, the fuel pressure fluctuates between 39.5 to 41.5, so could it be a bad fuel pressure sensor, faulty fuel injector(s) or the manifold runner control o-ring?
Thanks in advance.
Thanks in advance.
