Hi to all,
I just recent bought a 2004 Mercury Sable which just turned over to 130K miles and in great condition visually. I have had one major head ache since my purchase and that is the whole alarm system going off by its self. Most of the time it's about 5pm but it can happen whenever. Seems like this is common for sables around this year. I have had the battery tested so not a battery or starter issue. I have had new batteries installed into the key fobs but no change. I've used WD-40 on the door latches and still no progress. Anyone have any suggestion or ideas on what I should do or try next?
Also not sure if it makes any difference but when I am in the car the "theft" light blinks even being unlocked and keys in the ignition. Seems a bit odd but I figured that could help some.
Thanks in advanced.
I've had this issue with my '04 Sable for several yrs. It used to wait several hours after I locked the car and went inside the house (usually went off in the wee hours of the morning much to the chagrin of my neighbors). But now, it will usually sound the alarm about 15 mins after I lock the car and walk away. Done the same thing as you squirting WD40 into the door latches. Changed out the switch under the hood, too. Nothing has worked. Everything I've read implies it's a dirty door latch...so, I looked into changing door latches while tearing into one at the JY and it's no easy task. It's not like me to not fix something...but, this car has 256K miles on it, has been written off as salvage vehicle due to hail damage 5 yrs ago and is beginning to look it's age with rust showing along the rockers. I've just lived with it by not locking it.
^+1. May check for a plunger switch underhood. If equipped, it's located underhood inside the lf fender about midway between the battery and firewall. Prior replacing it, may unplug for a few days to see if the alarm stops. If it turns out to be the culprit, you can then leave it disconnected or replace. Another place to check is the trunk latch switch.
