Hey there. I went to change the oil pressure switch on my 2003 Taurus with a 24 valve. The switch I took out doesn't match the replacement switch. The one called for is a 3/8 thread with a long flat nose. The one in the car (1u5t-9278) is a 1/4 thread with a short, beveled nose. It looks like someone put a 3/8 to 1/4 reducer in to accommodate this switch.
Has anyone seen this? My gut is to take out the reducer and just put the bigger switch in, but I can't figure out if there was a reason someone did this. This was my mother in laws car until about three years ago, and AFAIK she only had it serviced at her dealer in Florida.
I think mine looks like a quarter inch in a bushing to 3/8". Factory puts in what ever is in the inventory. Just tape it and put it in. Likely you are doing this due to leaks.
If anyone here can post a pic of DOHC not leaking, please post it. I have now 3 '03's in my stable, and had a '01 and all leak. My '03 Taurus had the pan gasket replaced by the dealer. It leaks less.
Oh it definitely has leaks but not here. The switch is electrically bad. Looks like I have what you have, a bushing so the 1/4 will fit. I'm just wondering if I take the bushing out can I just use the 3/8, but it sounds like I should just replace what is there.
My '03 Taurus bought used had the pan gasket replaced by Ford dealer. I can see blue silicone around some of the corners. Still leaks but less than my other two Sables.
Yeah, I want to reseal my pan but I DON'T want to take that exhaust down, so maybe I won't.
