Hi everyone.
I joined about a year ago when I first got my car, but have never posted until now. I've been searching for possible solutions to my issue, but haven't had any luck, so I figured I'd throw this out there and look for some suggestions.
I have a 2003 Taurus Wagon with the 3.0 liter engine in it. It's been running great since I got it, but today I noticed an issue.
I was on the highway and was attempting to pass another car. As I accelerated to about 4,000 RPM (give or take a couple hundred) the car began to act like it wasn't getting any gas. It stuttered and hesitated and sputtered. Laying off the accelerator caused the car to go back to running perfectly at 75 MPH.
So I tried again, and again I got to about 4k and the stutter came back. It really does feel like the engine isn't getting any gas.
When I got off of the highway for work, I tried accelerating from a dead stop. It goes past 4k just fine when it's not going anywhere near highway speeds. Basically, it only has the issue when you're going highway speeds and trying to accelerate to pass. For instance, from a stand still to 55 MPH, it didn't hesitate or stutter once, and it went past 4k for two shifts.
The car only has 64,000 miles on it. I got it with 50,000 on it. I haven't really done much as far as tuning up goes because it has run so well since I got it. With that said, I'll be doing a thorough tune up on it in the next couple of days (or, I should say, the ASE certified mechanic that I work with will be doing it for me). My mechanic friend said that since the car has low mileage on it, it's possible that it sat for a while without being driven and that could have caused some of the things that normally wouldn't need to be replaced yet, like spark plugs and wires, to possibly need replacement earlier. I know for a fact that the car sat on a dealers lot for at least six months before I purchased it, so it's possible that it did a good amount of just sitting around not being driven before I took possession of it.
I have put a can of Sea Foam into the gas to try and clean up the injectors in case that was part of the problem. I will have a new fuel filter installed, a new air filter installed, new spark plugs, and new plug wires.
I was wondering if anyone else had any suggestions for things that I should possibly look for while trying to fix this?? I figure the car needs a tune-up regardless, so no matter what I'll be changing out the items listed above. But if anyone has any idea if it might be something else causing this, let me know so that I can check that out while we're working on the vehicle.
Thanks for taking the time to read this.
Jeff
Jeff
