Anyone know of a part number for a belt that DOESN'T have a/c..
Apparently this one doesn't have it and never did..No-one seems to have any clue.. Along with a routing diagram..
willie
Hello All- My Sable wagon 2001 LE DOHC 90K miles (my 3rd model), regularly driven. I have been getting an error code P0453 since the summer. Comes out as "evap feul tank pressure sensor high input".
Long story as short as possible- All sources except Ford continually come up with no part or...
I have a 2007 Ford Taurus the transmission is good, then I have a 1993
Ford Taurus wagon, it’s only driving in 1st gear, will the transmission interchange?
About two or three months ago my cigarette lighter and 12v power outlet went out. I just replaced the fuse and it still hasnt fixed the problem. I have check all connetions, there seems to be nothing wrong with any of it. how would i go about fixing the problem. i also put my phone charger in...
Ford Taurus 2011
Dumb mistake but tried to install a battery with opposite terminal and quickly realized it. Issue is the Radio doesn't work anymore. None of the buttons respond but he interface still works and shows Temp and A/C indications. Could there be a fuse for this or did i fry the radio?
2005 Duratech in a Taurus SEL.
For a while now I have been getting the horrible screeching when I go to start the car which is indicative of a bad starter bendix or ring gear/flex plate. It was getting worse and I knew one day it would not start. Took out the starter and the bendix looked fine...
