Key works fine in ignition/trunk/pass door, so I don't think the key is the problem.
I was rear-ended just before I started having this problem, but it was fairly low-speed and nothing else is really that wrong but it definitely got jarred if that could help diagnose the problem.
When I put the key in it doesn't want to turn immediately, I kind of have to wiggle it left and right before the seems to catch and unlock the door.
Any ideas, hopefully an easy fix I can attempt on my own? Just annoying at this point as I can get it unlocked within a few tries, but I'd like to nip it in the bud if this may worsen or potentially hurt the locking mechanism.
Thanks in advance!
Did you try shooting graphite lube or lithium grease into the lock? or coating the key with some lube before you stick it in the lock - the pins might be sticky from lack of lube. WD-40 may work temporarily but you'll need something that will stay put long-term.
Excellent advice!
