Greetings,
Hose started leaking from the 'T' joint. Hose goes from engine, bends around the battery, then connects to the radiator. Hose from T goes around the front of the engine to the passenger side.
Is this the lower hose?
Thanks,
Robert
2002 SES 24V DOHC
I cant find just that tee yet. So tomorrow im going to take it apart and get the measurements and see if i can find some kind of automotive tee that will fit otherwise its $166 dollar assembly. those pictures were from fordparts.com. If you find a fix let me know
good price. I made my own tee and so far no leaks. i used a hose splice connector and then drilled and tapped it with a 3/8 fitting. and some ptfe. So if this doesnt work ill be checking that link
