2002 evaporator core replacement
464 Views 6 Replies 6 Participants Last post by  sheila
2002 sable, DOHC, last year the compressor locked up and I replaced pretty much everything in the system minus the evaporator. Put it all back together and there was a slow leak - lost most of the refrigerant over a month or so. There would always be about 10 or 15 lbs left. I put some dye in but could never see it. That only leaves a few options so I bought a sniffer from harbor freight and sure enough it alerted very strongly when brought next to the evaporator drain. I know that's a big job but it's gotta be done so here it goes!
Started by removing the radio and plastic piece with the adjustable vents on it, glove box, ash tray. Gotta remove the steering wheel, remove bolt above the flex joint near the firewall to disconnect the steering linkage. Remove the multi switch for turn signals/headlights, unplug harnesses. Four nuts and the whole steering wheel assembly comes out.
Car Vehicle Gear shift Motor vehicle Steering part
I crawl under and disconnect all the wiring harnesses near the driver side left wall, only a few connectors and it's all free. Then two big bolts on each side, front of the door sill, the whole dash will come out.
Car Vehicle Motor vehicle Hood Automotive design
Now we're getting somewhere! At this point I removed the center console, that's only a few bolts and it comes out giving more room to work. Now the whole black plenum box has to come out. Unfortunately this means disconnecting the heater lines and AC lines from behind the engine. At least on my DOHC, this is pretty hard to get to so my trick is to remove the upper intake manifold, wiper motor and plastic cowlings around the windshield. This gives you pretty good access to the hoses on the firewall as well as a couple nuts you remove to loosen the plenum inside.
Hood Automotive tire Motor vehicle Rim Gas
Drained radiator, disconnected heater hoses from the heater core. Make sure no pressure in the AC system, then disconnect the AC hoses from the evaporator core. Cap immediately to keep out moisture.
Now the plenum box can come out inside the cabin. There's a duct on the floor that catches it and I had a hard time getting it loose. See the arrow in the pic below, that duct goes way under the carpet and I didn't want to take all the carpet up. The duct is thin and somewhat flexible, I was able to bend it around but difficult. Not sure how it'll go reinstalling.
Motor vehicle Vehicle Hood Car Automotive design
Finally the plenum box can come out. I removed the bolts around the middle and slowly worked apart the halves, lots of little plastic catches around it. Be careful, there's a blend door linkage thingy that has to be snapped out of the top part. I could now finally get to the evaporator core and pull it out. Thankfully, the leak is pretty obvious:
Purple Sleeve Violet Magenta Gas
There's a hairline crack you can actually see looking at it close. I'm 6 or 7 hours into it at this point, now waiting for a new evaporator core. Here's hoping for long lasting, ice cold AC this summer!
See less See more
5
  • Like
Reactions: 3
Now I understand why they charged me $1300 to replace mine on a '06 500 several years back. That is a very large job.
  • Like
Reactions: 3
That's insane, well done though
  • Like
Reactions: 2
Thanks all, it was a big job but very doable, basically two solid days of work. Someone had obviously been into this before as some stuff was broken, the bracket to mount the vacuum control box was gone, some nuts were not tight, and I even found an AC quick-connect tool lodged within the steering linkage! The old evaporator has a 03 date on it, car was manufactured in 02, hmm? I drained about 1oz of oil out of the old evaporator so I added that much back in thru the service port. This is the linkage that connects to the blend door after the plenum box is reassembled (gotta reach in through the outlet and snap it on)
Light Motor vehicle Gas Auto part Metal
One thing that made reassembly easier is removing this little piece that connects to that duct in the floor. Two screws, you set it in first and then the whole plenum box can connect up to it.
Motor vehicle Automotive design Hood Automotive tire Automotive lighting
After that it's just putting everything back together. I vacuumed the system down and it held vacuum overnight, so I charged it with the recommended amount (0.96kg) and so far everything is working well. Hopefully it will stay that way for a long time to come! Thinking about it, I suspect that old evaporator was broken from connecting/disconnecting the suction hose. Definitely be gentle working those connections on and off! This car only has 114k on it. The exterior paint is in poor condition but we live in AZ, no rust problems here! I just saw the average price of a used car is now $30k, so I feel ok about spending some effort keeping this one going :)
See less See more
2
  • Like
Reactions: 2
I bought a 2006 in 2007 with 9k miles on it. I paid $9k for it and had two years warranty on it. It developed a whistle in the ductwork and I took it in for warranty work. The called me up and said it was a two day job since they had to take the dash out and replace the ductwork. Sounds like they had to do everything you did and took the same amount of time.
  • Like
Reactions: 1
Well done! Appreciate your write up! Unforunately I will be pulling the dash and heater box on my 02 vulcan for a plugged heater core. No need to recover refridgerant, but still not looking forward to the repair
  • Like
Reactions: 1
May check out the youtube video: "Heater core shortcut" by realfixesrealfast. May search on here or youtube.
  • Like
Reactions: 1
