Hey y'all, I am new to the forum and have really enjoyed reading several threads I have found here. I have a 02 Taurus with a Duratec DOHC 3.0. Since I have had it (about a year) it would randomly misfire on the interstate but it would always "push through" it after a a couple of minutes. Last week I was on my way home when the misfire happened so I pulled over, got a reading from AutoZone and I had a misfire on cylinders 4 & 5. Trying to avoid a tow truck fee I drove it the rest of the way home, which was about 25 miles. I got home and replaced all six plugs, ignition coil, wires and bypassed the EGR by putting EGR vacuum line on a new DPFE sensor. It still misfires, especially under a load (even AC) and I noticed that it seems louder than i remember but it could be my paranoia. I am afraid that i ruined/clogged the cats driving it home and possibly warped the exhaust manifold. It is worth the fix? How would yall diagnose this?
after replacing spark plugs, wires and coil, what codes do you have now? You need to get them rescanned, or buy a cheap bluetooth scanner on ebay and do it yourself.
I have now 2 '03 DOHC and sold a '01 DOHC. Had problems with coils, wires, and Autolite plugs. Misfires with no codes.
Any issue with cats will set a code. It is emissions critical while others are only if they are really bad. You would do well to get a cheap code reader and look for pending codes. Pic of nearly new Motorcraft wires on new Autolite plugs.
What do you mean you bypassed the EGR? Why did you do that? Engine will never run right with EGR system disabled.
