1 - 2 of 2 Posts
i have a 2001 mercury sable dohc had a 234 misfire to start off with change plus wires and coilpack ended up with 456 misfire and changed all again with oem both times same thing had a back pressure test done on cat its good.what would cause these issues with the car only having 91000 miles on it.also car wont go over 15 mph either.
it kinda sounds like a couple of spark plug wires are crossed.
There's also one thing to check.. under the throttle body tube there's a vacuum hose that needs to be connected. if it isn't, the car exibits the same symptoms.
1 - 2 of 2 Posts
