1 - 2 of 2 Posts
Is it necessary to remove the entire steering collar from the vehicle? Once the CV joint/ shaft is out of the way, seems to me the lower ball joint could be pressed out and another pressed in right there?? Also, would it be possible, to push out the cv shaft from the splins if you turn the front wheel to the right so that it comes out at an angle? Thanks in advance.
1 - 2 of 2 Posts
