Hello, All.
I am in the process of replacing the "Bearings" and the " "Lower Ball Joints."
Now, I have it ready to do the replacements, and I need to remove the hub.
I need to remove the "Speed Sensor on Hub."
Can someone please let me know?
I have the bolt out, just need to remove it.
217936
217937
I figured it out.
Once you have the hub clear.
Use an extension from a ratchet, placing the extension on the backside, and hit the extension with a hammer a few times, and it pops right out.
I have replaced BJ but left the sensor in the knuckle. Just unplug the wire and let it go along with the knuckle. I had to replace one sensor that went dead. Had to drill it out. Corrosion bonded the sensor body to the knuckle.
