1 - 10 of 10 Posts
Hello all;
Fixed one thing, caused something else to mess up.
So, in the process of getting to that other thing, which is a water line against the firewall, I have a
Free Spinning Intake manifold bolt, that WILL NOT COME OUT!!
The left Upper Bolt.
Any idea's on HOW to get this bolt out?
It is tight feeling, you have to use a ratchet on it.
You cannot spin it with your finger, it is tight.
I have tried to put pressure on the bottom of the bolt shot, and ratchet at the same time, but that is a no go. It just spins and nothing else.
Any clues on how to get this piece of crap out of this thing?
Thanks
I would cut the hex off the bolt with a Dremmel, remove the upper intake, and see what is going on.
@Automender12345
I tried it, and it is a no-go.
will not do anything.
So, I am going to Walmart today and to Lowes.
To see if I can find a grinding wheel to go on my drill.
I have a small 18v drill that I will be able to use to grind the head of the bolt off with.
This is a nightmare.
Ford needs to be slapped silly for this stupid design.
It is about as bad as placing the horn switch on the blasted turning signal on my 83 Ranger.
One stupid mistake after another.
I love Ford, my favorite trucks.
But with the issues with this blasted car, I am starting to hate it.
See pic, the bolt threads into a brass slug molded into the lower intake plastic. If it is turning free, likely it is not holding. Loosen all the others and it may just pull off with the UIM.
Then is the issue of how to fix the threads.
Oh, that tiny picture, hard to see what you are supposed to be looking at.
I tried to pull up on it yesterday, and it did not budge.
I just went out there and tried it one more time.
And it will not budge.
I even tried it with a flathead screwdriver at the bottom of the bolt chamber, and still nothing.
So, going to have to go with the grinder, and hope I can get it past the bleeder from the fuel rail.
Discussion Starter #10
1 - 10 of 10 Posts
About this Discussion
4 Participants
carrzkiss
Full Forum Listing
