^+1 on removing the bottom black plastic air dam and with a garden hose and nozzle on a warm day, spray through the grill, then up between the condenser and radiator getting both surfaces and finally through the fans getting the backside of the radiator the best you can. You'll be surprised at how much "crap" flushes/rinses out. Be prepared to get wet, lol. I'm in an area where I get a lot of dirt/dust/cottonwood fuzzies.
I have hosed the condenser from front with a hose. Last did that on '03 Taurus, I removed the grille to do that. Issue was fans going to high with A/C on on warm day and sitting still.
Air dam is very important for temperature management.
Years ago, I had to drive along the St. Lawrence seaway for work. I had to hose the rad out every weekend for bugs. Big guys hatch out of the seaway. Also keep window cleaner and paper towels to keep the windshield simi-clean.
Last spring noted the central A/C vertical fan was not blowing much air up, mostly sideways. I took the screws out, lifted the motor/fan up and back. Used a hose and flushed the rad. Lots of dirt/mud and mostly dead bug parts flowing out. Then air flowing up much better.
AS to cars, everything in front of the fans is expected to get wet.
