Hello all, I have a 2000 vulcan w/ 80k. It has started running a little rough at idle. Sounds like it's missing or not firing all the time. I just installed new plugs and wires which didn't help much. Any ideas? I'm thinking maybe the fuel injectors are dirty. It seems fine under load and at higher rpms so I don't think it's a fuel filter. I also don't think it has a vacuum leak. What would you check next?
CEL is not on and no codes in computer.
Thanks for any help!
Remove your coil pack and look for "cracks" or "blemishes"...be sure to check the bottom of it.
Might be your idle air control (IAC) - use your browser search on 'idle' or 'iac' on the Topic Finder (see navigation bar at the top of the page).
You can try removing it. Then you clean it with throttle body cleaner or any cleaner that evaporates completely. This has always worked for me.
Others say, forget cleaning and use your next $60-80 to buy a new IAC.
Thanks for the suggestions, I'll give them a try. I had IAC issues on my mustang but it had erratic idling, sometimes high, sometimes normal, it never sounded like it was "missing". I was wondering if hooking up a timing light to each wire would show anything, maybe it flashes too fast to see a miss. Of course that might tell me which cylinder but not the cause.
Thanks again!
QUOTE (OldWagon @ Apr 10 2009, 05:32 AM) index.php?act=findpost&pid=716690
You can try removing it. Then you clean it with throttle body cleaner or any cleaner that evaporates completely. This has always worked for me.[/b]
I just did this per OldWagon's instruction. I think it helped a lot.
QUOTE (woody258 @ Apr 10 2009, 07:40 PM) index.php?act=findpost&pid=716809
...I was wondering if hooking up a timing light to each wire would show anything, maybe it flashes too fast to see a miss. ....[/b]
Sounds like a good idea. Erratic flashing would be easy to see at idle, as any one cylinder will flash only a few times per second at 1000 rpm.
As you say, though, I wouldn't know what to do with the information... and IDK why you wouldn't be getting a misfire code and SES/CEL light.
